Unconfigures the CCM interval of the association or MEP to the default interval.
domain_name |
Specifies the domain associated with the MA. |
association_name |
IEEE 802.1ag or ITU-T Y.1731 association name. |
port_list |
Specifies the ports to unconfigure. |
| up |
Enter this variable if you are changing the time interval for sending a CCM on an UP MEP. |
| down |
Enter this variable if you are changing the time interval for sending a CCM on a DOWN MEP. |
1000 ms.
Use this command to revert the CCM interval of either the association or the MEP back to the default CCM interval.
The following command changes the interval the UP MEP (previously configured on port 2:4) uses to send CCM messages on the 350 association in the finance domain to the default of 1000 ms:
unconfigure cfm domain finance association 350 ports 2:4 end-point up transmit-interval
This command was first available in ExtremeXOS 12.3.
